GOD JUL!
God jul/hjul til alle!
Det blir utvilsomt en god romjul for meg
Good news! Your order from Flyin' Miata has been shipped. If you requested
UPS as the shipping method, you can follow its progress through the
following link:
http://www.flyinmiata.com/us/track.php? ... =blablabla
Item Qty Qty Qty
Expected
Number Description Ord. Shp. Bck. By
07-16500 Link ECU, keypad & temp sensor 1.00 1.00 0.00
1994-95 1994-95
Mazda MX-5
07-47010 Serial Link with USB adapter 1.00 1.00 0.00
04-41000 Injectors, 550cc, Set of 4 1.00 1.00 0.00
BALLAST with ballast resistors
07-77000 Data Log Lab, 1990-97 1.00 1.00 0.00
FULL MiataLink full version
07-26500 Boost Control Solenoid 1.00 1.00 0.00
1990-97 1990-97
13-97907 Bushing, swaybar end link 2.00 2.00 0.00
1 per each end of car (F or R)
13-97000 Suspension Bushings-non adjust 1.00 1.00 0.00
04-56200 NGK Extended Reach Spark Plugs 1.00 1.00 0.00
Heat #7, set of 4
07-36500 Link knock sensor & mount 1.00 1.00 0.00
1994-97 1994-97
36-50020 Hose Barb, M, 3/8NPT 5/8" Hose 1.00 1.00 0.00
(oil drain T28 turbo)
36-40230 HOSE, OIL, 5/8" PER INCH 20.00 20.00 0.00
(oil drain line)
36-70105 HOSE CLAMP, Winzer, 15-24mm 2.00 2.00 0.00
(oil drain hose)
35-46000 Drill Bit, 14.5mm (37/64") 1.00 1.00 0.00
(for oil drain/return)
35-46500 Tap, 3/8NPT 1.00 1.00 0.00
(for oil drain)
additional order confirmed via
The total amount of your order, including shipping, is a shitload of money...
- JohnBGoode
God Jul........................................ For min egen del ser jula ut til å ha sine tunge stunder. Det ser ut til at jeg tok livet av tyttebæra på lille julaften...... Baklengs i 80 setter sine spor kan man si..... Krattskogen har aldri vært så glissen langs riksveg 312. Når veivesenet i tillegg setter ut uønskede skilt med alskens unyttig informasjon langsetter vegen, blir det fort store rynker å rette ut. Men jula kommer okkesom..................ha en god en folkens
91 Cl. Red, Lille Rosin Style............
94 Laguna Blue Metallic 1,8
Det var usedvanlig trist! Håper den blir bra igjen om ikke altfor lenge!JohnBGoode wrote:God Jul........................................ For min egen del ser jula ut til å ha sine tunge stunder. Det ser ut til at jeg tok livet av tyttebæra på lille julaften...... Baklengs i 80 setter sine spor kan man si..... Krattskogen har aldri vært så glissen langs riksveg 312. Når veivesenet i tillegg setter ut uønskede skilt med alskens unyttig informasjon langsetter vegen, blir det fort store rynker å rette ut. Men jula kommer okkesom..................ha en god en folkens
