Vegard's roadster inspirasjon's tråd.
- Vegard
- Medlemsnummer: 0
GHO sin banebil.
Her kan du se den på tsukuba, de siste rundene er veldig underholdene!
copy paste fakta:
http://www.hundred-one.com/demo1.htm
GARAGE HUNDRED ONE issue blue TUNINGSPEC
Vehicle Model: NA8C
Engine
Maximum Output: 320PS (315hp) @ 8500 RPM
Maximum torque: 35Kg (253 ft-lb) @ 6,700 RPM
Built by: Maruha Motors
Displacement: 1930cc
Bore × stroke: 85.0mm × 85.0mm
Compression ratio: 12.7: 1
Intake system: TOYOTA 4AG individual throttles
ECU: MoTeC M48-ADV ROG
Ignition coil: MoTeC
CDI: MoTeC
Cam: Toda Racing 300 degree 10.7mm lift
Lifter: Toda Racing shim under bucket solid mechanical type
Valve spring: Toda Racing strengthened type
Timing gear: Toda Racing adjustable
Piston: Toda Racing forged 85.0mm φ
Connecting rod: Crower
Crank: Original crank lightened and polished
Head Gasket: Toda Racing 0.8 mm
Oil cooler radiator
Nitrous oxide: Dry shot × 8
Drivetrain
Clutch: ATS carbon clutch
Transmission: Seq girkasse
LSD: ATS carbon LSD
Final Drive Ratio: 5.1:1
Suspension
Shock absorber: OHLINS MH-P
Spring: Swift F 13Kg R 11Kg
Control arms: Manatee Racing adjustable
Uprights: SP-TEC
Tire/Wheel
Wheel: Panasport F: 15X8J R: 15X8.5J
Tire: Yokohama A048 F: 225/50-15 R: 225/50-15
Brake
Brake rotor: For NA8
Brake pads: F: ED CC-M R: ED CC-M
Body
Body reinforcement: Increase spot welds + roll cage
Front spoiler: Garage Hundred One wide body
Hood: Garage Vary lightweight type
Door: FRP lightweight
Hard Top: Garage Vary lightweight type
Over Fender: NOPRO
copy paste fakta:
Vehicle Model: NA8C
Engine
CDI: MoTeC
Oil cooler radiator
Drivetrain
LSD: ATS carbon LSD
Suspension
Uprights: SP-TEC
Tire/Wheel
Brake
Body
Over Fender: NOPRO
- DrHolm
- Medlemsnummer: 554
tror det er en del spenn og timer i benken på den motoren der..
sett forskjellige tall på den der.. og endel vettuge argument for at talla ikke stemmer momentet den har oppgitt der, på det turtallet, er unormalt høyt feks.. det skal seriøst mye til å få så mye effekt og moment av en sånn motor, med så "normale" kammer, selv om det er 2.1 l. den ligger like under bmw m5 e34 3.6l motorn i moment liksom. i call bs.. 2.1 l suge BP motor. med nesten 350nm..
-*Snylter*-
Står jo også i lista der at den har NOS...
100-150 shot NOS så er nok 300 reellt.
Men i motoren, er det nok ikke voldsomt mye over 200-250.
Dessuten er vel den knapt nok kjørbar på gate, hehe.
Rimelig aggressivt trim på den der.
For ikke snakke om Maruha stroker kit som koster like mye eller mer en en bra NA :p
- Tonny_B
- Medlemsnummer: 927
Kansje litt avsporing fra tråden, men er det noen somvet omtrent hvor kvasse kammene kan være før man er nødd og gjøre noe med toppen?
Jeg har planer om og skaffe meg noe ala 275-280 graders kammer med 10mm løft, hvis jeg da slipper og gjøre noe spes med toppen? annet enn og planslipe den og vanlig overhaling...
Tror man bør gjøre noe med toppen allerede før man bytter kammer..Predator wrote:Kansje litt avsporing fra tråden, men er det noen somvet omtrent hvor kvasse kammene kan være før man er nødd og gjøre noe med toppen?
- Vegard
- Medlemsnummer: 0
Re: Vegard's roadster inspirasjon's tråd.
Svart NA med n2 flares... mmmm, ser så rå ut helt svart. Kunne såklart hatt litt breiere felger/dekk...
