https://www.instagram.com/p/BvDbh7_gwXA/
Greg Peters;
"Since I posted a supercharger meme this week I suppose I should post some actual data, lol.
This is a well set up Rotrex Miata overlaid with one of the dyno pulls of my car where it made the identical peak HP (my car = dark blue torque/light blue HP). Both runs at 12-13psi.
I'm not saying superchargers are "bad" or turbos are "best."
All I'm saying is that peak HP doesn't tell the whole story, "area under the [torque] curve" is a much better representation of a cars manners/strengths/weaknesses.
Also, in superchargers defense, these graphs don't show transient response (roll-on response).
The Rotrex might only make 190wtq @ 4500 compared to 235wtq from the turbo, but that 190wtq is available in 0.00 seconds once the pedal hits the floor.
My car is extremely responsive, but all turbo setups will have lag. To me, although instant response is great, the power onset of a turbo just takes a little learning and you'll be able to get that power exactly when you want it.
Also, if these two setups were on stock engines, you'd be way less likely to banana your rods on the supercharger, while still making the same peak horsepower as the turbo. S/C systems are also easier to install and less complex "
Jeg synes dette var en veldig grei oppsummering og sammenlikning mellom Rotrex og Turbo.
Eneste er at han tar feil når han sier areal under dreiemoment - kurven, det korrekte er at det er arealet under hp kurven som bestemmer hvor mye omph du har over et gitt rpm området.
Jeg har lenge vært en ihuget Rotrex fan, men blir mer og mer overbevist om at eventuell tvangsmating er turbo.
Mr. Peters har mange gode videoer som du finner her.
Turbo vs Rotrex
Turbo vs Rotrex
Re: Turbo vs Rotrex
Njaa... Veldig grovt forenklet så er det dreiemomentet som gir akselerasjon, og hestekrefter gir toppfart. Omph'et du opplever når du trår gassen i bånn er mer dreiemoment enn hestekrefter.Stalfa wrote: ↑16 Mar 2019, 13:17 Jeg synes dette var en veldig grei oppsummering og sammenlikning mellom Rotrex og Turbo.
Re: Turbo vs Rotrex
Jeg mener du tar feil.
http://www.epi-eng.com/piston_engine_te ... torque.htm
"Think of it another way: In cars of equal weight, a 2-liter twin-cam engine that makes 300 HP at 8000 RPM (197 lb-ft) and 400 HP at 10,000 RPM (210 lb-ft) will get you out of a corner just as well as a 5-liter engine that makes 300 HP at 4000 RPM (394 lb-ft) and 400 HP at 5000 RPM (420 lb-ft). In fact, in cars of equal weight, the smaller engine will probably race BETTER because it's much lighter, therefore puts less weight on the front end. AND, in reality, the car with the lighter 2-liter engine will likely weigh less than the big V8-powered car, so will be a better race car for several reasons."
Re: Turbo vs Rotrex
Siste avsnitt i artikkelen du linket til:
Note that at 5252 RPM, torque and HP are equal. At any RPM below 5252, the value of torque is greater than the value of HP; Above 5252 RPM, the value of torque is less than the value of HP.
Det er altså dreiemomentet du kjenner mest av opp til 5252 rpm, og hestekreftene over 5252 rpm.
- torbra
- Medlemsnummer: 1122
Re: Turbo vs Rotrex
Setter du inn en Rotrex med CCR brakett har du plass til en turbo OGSÅ!
-91 BRG-SE, Schneller Heinz
- Legendary
- Medlemsnummer: 978
Re: Turbo vs Rotrex
Enkleste løsningen på dilemmaet:
- skaffe seg en feit amerikaner med V8-er, så får man oppfylt dreiemomentbehovet!
- montere Rotrex på MX-5en, så får man racecar-følelsen med umiddelbar respons!
Re: Turbo vs Rotrex
Min påstand er at det er arealaet under hk kurven i et viss turtallsintervall som bestemmer akselerasjon. Ikke under moment kurven slik som Peters skriver.
Dette gjelder vel bare for Miata, Mx5'er som har motorer som leverer nm kjenner du vel dreiemomentet enda høyere?
Re: Turbo vs Rotrex
Jeg vil tro at formelen de brukte i artikkelen er universell, men det hadde vært interessant å se dynokurvene for en ekstrem høyturtallsmotor. For eksempel Renault sin 3 liters F1-motor som i 2006 leverte smått imponerende 900 hk ved 19.250 rpm (!) - uten pustehjelp.
Re: Turbo vs Rotrex
Det er hestekreftene som du kjenner uansett turtall og hestekreftene er de kreftene som gjør at noe skjer, gir akselreaksjon og toppfart. Så den kurven som er av interesse for resultatet er hk kurven. (Men siden hestekreftene er produktet av turtall og moment så blir det jo dårlig med hestekrefter uten moment).
