Torsen LSD -94 miata
Var det Torsen LSD på de fleste miata fra 94? Hvordan kan man finne ut om man har det?
http://www.miata.net/garage/vlsd.html(Q)How do you identify Torsen's without dissasembly?
(A)The Torsen won't always turn both wheels when you turn the driveshaft, sometime if they are cold they will. One way is to take out the fill plug to see the Torsen gears which is hard to do because of the angle. Another way is to attempt to turn both half shafts in the same direction at the same time (tranny in neutral), can't be done with a Torsen. The foolproof way is to pull the stub axle on the type 1 or the drive axle on the type two. If you don't see a bar and can see directly thru the diff. it is a Torsen. If there is a bar, (spider gears) it's an open.
