Fiffig verktøy
koteng
Post by koteng »
Jeg tror ECE betyr at bilen er laget innefor EU sine regler for biler.
World Forum for Harmonization of Vehicle Regulations
The core of the Forum's work is based around the 1958 Agreement, formally titled "Agreement concerning the adoption of uniform technical prescriptions for wheeled vehicles, equipment and parts which can be fitted and/or be used on wheeled vehicles and the conditions for reciprocal recognition of approvals granted on the basis of these prescriptions". This forms a legal framework whereby participating countries agree a common set of ECE Regulations for type approval of vehicles and components. When an item is type approved for a regulation by one participating country, then the approval is accepted by all other participating countries.
Originally, the 1958 Agreement allowed participation of ECE member countries only, but in 1995 the agreement was revised to allow non-ECE members to participate.
Items approved as meeting an ECE Regulation are marked with an E and a number, within in a circle. The number indicates which country approved the item, and other surrounding letters and digits indicate the precise version of the regulation met and the type approval number, respectively.
List of participating countries
As of 2006, the participants to the 1958 Agreement, with their ECE country code, are:
Code Country
1 Germany
2 France
3 Italy
4 Netherlands
5 Sweden
6 Belgium
7 Hungary
8 Czech Republic
9 Spain
10 Serbia
11 United Kingdom
12 Austria
13 Luxembourg
14 Switzerland
16 Norway
Code Country
17 Finland
18 Denmark
19 Romania
20 Poland
21 Portugal
22 Russian Federation
23 Greece
24 Ireland
25 Croatia
26 Slovenia
27 Slovakia
28 Belarus
29 Estonia
31 Bosnia and Herzegovina
32 Latvia
Code Country
34 Bulgaria
36 Lithuania
37 Turkey
39 Azerbaijan
40 Republic of Macedonia
42 European Community
43 Japan
45 Australia
46 Ukraine
47 South Africa
48 New Zealand
49 Cyprus
50 Malta
51 Republic of Korea
52 Malaysia
Most countries, even if not formally participating in the 1958 agreement, recognise the ECE Regulations and permit the use and importation of ECE-approved vehicles.
May the force be with you!
Roger
1999 NB Standard Silver importert fra L.A USA
koteng wrote:Jeg tror ECE betyr at bilen er laget innefor EU sine regler for biler.
Tror ikke det.
Det er i såfall unødvendig siden den rammenummer-serien som verktøyet er laget for er til biler produsert for Europa.
koteng
Post by koteng »
Tror ikke det.
Mulig at det er unødvendig, men verktøyet kan jo opprinnelig være laget for å brukes verden over.
Har du funnet noen i denne databasen som ikke det står ECE på da?
Roger
koteng wrote: Mulig at det er unødvendig, men verktøyet kan jo opprinnelig være laget for å brukes verden over.
Du har et godt poeng !
Kjøper den.
B1ackBoX
Medlemsnummer: 718
Post by B1ackBoX »
Noen som har dokumentet som forteller hvordan legge inn databasene i programmet, som de evt kan sende meg, eller gi meg en veiledning om hvordan jeg gjør det. Siden hvor dokumentet kan hentes fra er ikke mulig å komme inn på...
[rip]1990-Vectra 2.0L
[x]1990-Sierra 2.0L
[x]1991-Civic 1,3L
[rip]1989-Accord 2.0L
Vegard
Medlemsnummer: 0
Post by Vegard »
JMZNA18B201117104
Kunne en av dere med programmet sjekket den for meg.
Vegard wrote:JMZNA18B201117104
Produsert 28 des 1990
Bilens Farge : SU
Interiørfarge : NA0
modell år : 1989
Normal Diff.
uten abs
B1ackBoX
Medlemsnummer: 718
Post by B1ackBoX »
Har lagt inn programmet, men hva jeg enn gjør -får jeg ikke lagt inn databasene. Og den installasjonsmanualen på russisk skjønner jeg ikke noe av.
Noen som kan hjelpe? trinn for trinn forklaring feks. :)
[x]1990-Sierra 2.0L
[x]1991-Civic 1,3L
B1ackBoX wrote:Har lagt inn programmet, men hva jeg enn gjør -får jeg ikke lagt inn databasene. Og den installasjonsmanualen på russisk skjønner jeg ikke noe av.
Det er en installasjonsmanual på engelsk der også
Etter sommerturen har jeg fått spørsmål på dette rammenummeret:
JMZNA18C200515622
Min database feiler.
Andre som kan prøve ?
Eier av bilen er spesiellt opptatt av hva som sies om diffen.
Rudolf wrote:Etter sommerturen har jeg fått spørsmål på dette rammenummeret:
JMZNA18C200515622
Noen som har prøvd dette rammenummeret ?
:roll:
Fikk feilmeld eg også der gitt,
Vidar ?
Rudolf wrote:Vidar ?
Jeg har lagt inn windoze på nytt igjen, så jeg har ikke fiffigeverktøy inne på PCn nå..
Men kan prøve å legge det inn å se. men etter som jeg bruker de samme filen, regner jeg med å få samme feilmelding..
SweetMX5
Post by SweetMX5 »
klan noen fortelle meg hva jeg har på bilen min? jeg har bilstein dempere og en normal (åpen??) diff?
O:'01 Yamaha R1 1000cc
O:'00 BMW 318CiA 1.8
X:'99 MX5 1.6 Kompressor
X:'97 MX5 1.6 Turbo
